[petsc-dev] refactoring petsccusp.h needed
Karl Rupp rupp at mcs.anl.gov
Fri Mar 15 18:46:05 CDT 2013
Hi Paul,
> For GMRES, the current performance of VecMDot_SeqCUSP sucks. I have an
> solution, but I haven't tested all cases yet.
> For BCGS, some part of the algorithm is broken but I don't know what it
> is. By broken, I mean that CPU and GPU residuals diverge fairly quickly.
Since I just stumbled over VecMDot_SeqCUSP() when interfacing ViennaCL:
Do you know what was the reason why the 'old' version was replaced by
this expensive call to gemv() including the creation of temporaries,
etc.? Just writing a custom kernel with one work group per dot-product
should do the job perfectly, shouldn't it?
Best regards,
Karli
