[petsc-dev] PETSc-Cuda with gfortran 4.7
Nystrom, William D wdn at lanl.gov
Fri Mar 15 11:50:11 CDT 2013
OK.  Just wanted to make sure I was not hijacking the list for an unintended purpose.
Dave
From: petsc-dev-bounces at mcs.anl.gov [petsc-dev-bounces at mcs.anl.gov] on behalf of Karl Rupp [rupp at mcs.anl.gov]
Sent: Friday, March 15, 2013 10:42 AM
To: petsc-dev at mcs.anl.gov
Subject: Re: [petsc-dev] PETSc-Cuda with gfortran 4.7
Hi Dave,
my email was a remark for Asmund to get his code compiled. :-)
Sorry if this wasn't clear enough...
Best regards,
Karli
On 03/15/2013 11:15 AM, Nystrom, William D wrote:
> Hi Karli,
> I'm not sure what point you are trying to make below.  As I indicated in my emails, I am using
> 4.7.2 compilers for everything except nvcc and 4.7.2 is the default version of compilers for my
> distro, Fedora 17.  However, nvcc constrains the version of compilers based on the Cuda
> distribution.  Cuda 5.0 requires 4.6.x or earlier.  Cuda 4.2 requires 4.5.x or earlier, etc.  Perhaps
> Cuda 5.1 will support 4.7.x but I have no idea when it will be released.  The procedure I shared
> below allows one to restrict use of 4.6.x to only nvcc.
> Also, I don't have experience with other distros like Debian or Ubuntu.  So I can't speak with any
> confidence on them although I don't see why the nvcc.profile approach would depend on the
> distro.
> Also, I'm just trying to share my experiences with building petsc in a 4.7.2 compiler environment
> to help Asmund.  If this is not appropriate for this mailing list, I'm happy to communicate directly
> with Asmund.
> Best regards,
> Dave
> Sent: Friday, March 15, 2013 9:43 AM
> To: For users of the development version of PETSc
> Cc: Åsmund Ervik
> Hi guys,
> depending on the distribution you are using, there may be multiple
> versions of GCC already in the repository. For example, on Debian-based
> distributions you can have multiple versions of GCC installed, which
> show up in the package manager as gcc-4.6, gcc-4.7, etc.
> Ubuntu for example even allows you to switch between the versions
> seamlessly using
>    $> sudo update-alternatives --config gcc
> An example can be found here:
> http://askubuntu.com/questions/182027/how-to-use-gcc-4-7-in-place-of-4-6-ubuntu-12-04
> Aside from that, it is still not satisfactory for us to keep
> recommending other compilers. GCC 4.7 will soon be the default on many
> distributions (if it isn't already)...
> Best regards,
> Karli
> On 03/15/2013 10:36 AM, Nystrom, William D wrote:
>> Hi Asmund,
>> In petsc-dev, files with a .cu extension are compiled with nvcc.
>> I also tried the suggestion of soft linking an acceptable version of gcc/g++ into
>> /usr/local/cuda/bin.  I think I used a gcc/g++ from a compatibility package that
>> I installed with yum.  That did not work for me either.  I think the issue might
>> have been related to that version being in the ccache directory but am not sure.
>> The only solution I got to work was to install a new, acceptable version of the
>> GNU compilers by actually building from source and installing in its own location
>> such as somewhere in your home directory or in some place like /usr/local or
>> /opt.  Also, if you use the "--program-suffix=46" configure option, I think you
>> may also need to softlink gcc46 to gcc and g++46 to g++ in your install directory.
>> I could check that when I get home this evening as well as checking my build
>> script to make sure there is not something important in it to pass on.
>> For me, it took about about an hour to build gcc 4.6.3, once I had learned the
>> various things I passed on in the earlier email.  So you may have to just build
>> a version of gcc rather than using a version from your distro's package system.
>> BTW, what distro are you using?  I don't believe that nvcc uses gfortran.  It uses
>> g++ and maybe also gcc.  Also, there is nothing special about gcc 4.6.3.  You
>> could build an earlier version of gcc such as gcc 4.5.x or gcc 4.4.x.  I chose
>> gcc 4.6.3 because it was the most up to date version that was supported by
>> nvcc from the Cuda 5 distribution.
>> I'll write more from home this evening when I can check some things on my
>> system.
>> Cheers,
>> Dave
>> From: Åsmund Ervik [Asmund.Ervik at sintef.no]
>> Sent: Friday, March 15, 2013 7:21 AM
>> To: petsc-dev at mcs.anl.gov; Nystrom, William D
>> Hi Dave,
>> The errors occur when compiling these CUDA files:
>> mpiaijAssemble.cu, aijcusp.cu, mpicusp.cu and veccusp.cu
>> I assume these are compiled with nvcc, but I haven't triple checked that.
>> I had not tried your trick with setting the C compiler in nvcc.profile.
>> I did, however, try symlinking gcc-4.4 binaries into /usr/local/cuda/bin
>> (as was suggested in one stackexchange post I found), but this produced
>> an error during configure. Using your nvcc.profile, it gives the same error:
>> CUDA version error: PETSC currently requires CUDA version 4.0 or higher
>> - when compiling with CUDA
>> Even though I have CUDA 5.0 installed. Just to be sure, are there
>> binaries beside gfortran, gcc and g++ which must be found in the
>> CUDA-specific gcc-4.6 folder? I have both gcc variants installed through
>> the packaging system of my distro, so I cant't tell which belong to the
>> 4.6 variant.
>> Asmund
>> On 13. mars 2013, wdn at lanl.gov wrote:
>>> Asmund,
>>> Do the failures you report below occur in cuda code that is ultimately compiled with nvcc?
>>> I have not had problems compiling petsc-dev with cuda support on a Fedora 17 system
>>> which uses gcc-4.7.2 and gfortran-4.7.2.  However, I have gcc 4.6.3 installed also and
>>> have nvcc pointed at it by using the /usr/local/cuda/bin/nvcc.profile with a couple of lines
>>> added.  So, when I build petsc-dev on my Fedora 17 system, it uses gcc-4.7.2 and
>>> gfortran-4.7.2 for everything except cuda code located in .cu files.  I would worry about
>>> removing some functionality in 4.7.2 with your suggested modification.
>>> Thanks,
>>> Dave
>>> Dave Nystrom
>>> LANL HPC-5
>>> Phone: 505-667-7913
>>> Email: wdn at lanl.gov
>>> Smail: Mail Stop B272
>>>          Group HPC-5
>>>          Los Alamos National Laboratory
>>>          Los Alamos, NM 87545
