[petsc-dev] PETSc-Cuda with gfortran 4.7
Wed Mar 13 20:08:52 CDT 2013
> compiler-bindir = /home/wdn/Packages/Gcc/gcc_4.6.3/bin
Ah - thats good to know.
Thanks.
Satish
On Wed, 13 Mar 2013, Dave Nystrom wrote:
> Attached is nvcc.profile and nvcc.profile.orig.  See the last line in
> nvcc.profile.
> Also, to build gcc 4.6.3 on Fedora 17, I needed to follow the following
> procedure.
> yum install gcc mpfr-devel libmpc libmpc-devel glibc-devel glibc-devel.i686
> configure --prefix=where_to_install \
>           --program-suffix=46 \
>           --enable-languages=c,c++,fortran
> make
> make install
> Not sure why glibc-devel.i686 is needed for a 64 bit install but I had to
> have that for the build to work.
> Dave
