[petsc-dev] PETSc-Cuda with gfortran 4.7
Åsmund Ervik Asmund.Ervik at sintef.no
Tue Mar 12 02:35:23 CDT 2013
Hi all,
(This suggestion is two lines of code, so I hope it will survive the git/hg apocalypse/transition today. If not, I'll resend it tomorrow.)
Trying to compile PETSc with Cuda enabled, following the example in config/examples/arch-cuda-double.py, I get an error with gfortran 4.7.2 when making (configure works fine).
This error is apparently well-known with Cuda and gcc 4.7.2. To fix it, I added two lines to include/petsc-private/petscimpl.h:
#undef _GLIBCXX_ATOMIC_BUILTINS
#undef _GLIBCXX_USE_INT128
and everything works fine. I guess you should add this to petsc-dev, possibly with some if-statement around these lines.
Best regards,
Åsmund Ervik
