[petsc-dev] [mpich-discuss] MPICH migration to git
Sean Farley sean at mcs.anl.gov
Mon Mar 11 15:51:11 CDT 2013
On Mon, Jan 21, 2013 at 11:42 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Mon, Jan 21, 2013 at 11:18 AM, Sean Farley
> <sean.michael.farley at gmail.com> wrote:
>> On Mon, Jan 21, 2013 at 11:03 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> > On Mon, Jan 21, 2013 at 10:53 AM, Sean Farley
>> >> Well … did you try this with the equivalent mercurial feature:
>> >> largefiles?
>> > Nope, feel free. Most of the speedup is independent of the large files
>> > (which only change the git repo size from 78MB to 50MB).
>> Righto.
> Here's the clone without any "git-fat" business (18 seconds, versus 12
> seconds with git-fat):
> $ time git clone git at bitbucket.org:jedbrown/petsc-git
> Cloning into 'petsc-git'...
> remote: Counting objects: 300368, done.
> remote: Compressing objects: 100% (66014/66014), done.
> remote: Total 300368 (delta 233578), reused 300368 (delta 233578)
> Receiving objects: 100% (300368/300368), 68.18 MiB | 10.22 MiB/s, done.
> Resolving deltas: 100% (233578/233578), done.
> 18.067 real   16.042 user   2.080 sys   100.30 cpu
> $ du -hs petsc-git/.git
> 77M     petsc-git/.git
(Finally sending this out after sitting in my draft folder for far too
long. Not that it matters anymore.)
I think you're conflating the timings here. Let's first isolate network speed:
$ time git clone -n https://bitbucket.org/jedbrown/petsc-git-lean petsc-git
remote: Counting objects: 297100, done.
remote: Compressing objects: 100% (67974/67974), done.
remote: Total 297100 (delta 228357), reused 297100 (delta 228357)
Receiving objects: 100% (297100/297100), 41.22 MiB | 873 KiB/s, done.
Resolving deltas: 100% (228357/228357), done.
real 1m6.176s
user 0m7.732s
sys 0m2.283s
$ time hg clone --uncompressed -U
https://bitbucket.org/petsc/petsc-dev petsc-dev
streaming all changes
10150 files to transfer, 150 MB of data
transferred 150 MB in 181.4 seconds (847 KB/sec)
real 3m11.839s
user 0m5.111s
sys 0m5.308s
$ du -sh petsc-git
So, 1m6s for 50MB of data vs 3m11s for 150MB of data. Seems about spot
on, there.
$ time git co master
Already on 'master'
real 0m1.031s
user 0m0.455s
sys 0m0.462s
$ time hg up
4209 files updated, 0 files merged, 0 files removed, 0 files unresolved
real 0m0.987s
user 0m0.001s
sys 0m0.002s
Unsurprisingly, they are both the same. The difference in actual repo
size (not to be confused with the already committed binary files) will
come down once the new bundle2 format is implemented.
