[petsc-dev] patches for ICC/Cholesky preconditioner on GPUs
Sat Mar 9 15:51:08 CST 2013
On Sat, Mar 9, 2013 at 4:47 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Paul Mullowney <paulm at txcorp.com> writes:
> > Hi,
> > I've gotten GPU based icc preconditioners working with the following set
> > of patches. One uses ICC by loading an upper triangular matrix into the
> > cusparse class, and then setting the symmetry option, i.e.
> >      ierr =
> MatCreateSeqAIJCUSPARSE(comm,n,m,PETSC_NULL,num_entries_per_row,&A);CHKERRQ(ierr);
> >      ierr = MatSetOption(A,MAT_SYMMETRIC,PETSC_TRUE);
> > I've organized the implementations into 2 files:
> > 1) icc-cholesky-cusparse-organization.patch : This patch has the basic
> > infrastructure for calling the symbolic and numeric factorizations (both
> > ICC and Cholesky). Currently these routines make scoping calls to the
> > implementations in aij/seq/aijfact.c
> Can you write context like this into the commit messages? They are
> pretty opaque right now, but they are more likely to be read in the
> future than this email.
> This patch series does not have any tests. Can you add tests so that we
> can have a reasonable chance of not breaking it in the future?
> We can review on the mailing list, but I think we would prefer to use
> pull requests, mostly because comments there sort by context rather than
> by author. Barry, Matt, and others, do you prefer the granularity of
> email or bitbucket comments?
I can do either, but I think I prefer BB now.
I really do think everyone should put the component name at the start of
every commit.
   Mat
> A few comments now:
> > exporting patch:
> This first line should not be in the patch file. It should start with the
> lines below:
> > # HG changeset patch
> > # User Paul Mullowney <paulm at txcorp.com>
> > # Date 1362859983 25200
> > # Node ID 6be0d0f06ad18794377015b5ec468e11105b58b1
> > # Parent  6d60df3aadfe49f0bf640fa0a41fe3a423b88cf6
> > Implementation of ICC in this patch.
> Include the component (aijcusparse) in the commit message, otherwise we
> don't have a clue from the commit message what is actually being done.
> > diff -r 6d60df3aadfe -r 6be0d0f06ad1 src/mat/impls/aij/seq/seqcusparse/
> aijcusparse.cu
> > --- a/src/mat/impls/aij/seq/seqcusparse/aijcusparse.cu        Mon Feb
> 04 11:42:47 2013 -0700
> > +++ b/src/mat/impls/aij/seq/seqcusparse/aijcusparse.cu        Sat Mar
> 09 13:13:03 2013 -0700
> > @@ -1,12 +1,13 @@
> > -    Defines the basic matrix operations for the AIJ (compressed row)
> > +  Defines the basic matrix operations for the AIJ (compressed row)
> >    matrix storage format.
> >  #include "petscconf.h"
> >  PETSC_CUDA_EXTERN_C_BEGIN
> >  #include "../src/mat/impls/aij/seq/aij.h"          /*I "petscmat.h" I*/
> > -//#include "petscbt.h"
> > +#include <../src/mat/impls/sbaij/seq/sbaij.h>
> >  #include "../src/vec/vec/impls/dvecimpl.h"
> >  #include "petsc-private/vecimpl.h"
> >  PETSC_CUDA_EXTERN_C_END
> Not part of this patch, but PETSC_CUDA_EXTERN_C_BEGIN/END should be
> replaced with appropriate use of PETSC_EXTERN (as shown below). We are
> no longer mangling any public function names, so we can now compile
> PETSc using --with-clanguage=C++ and then call it from plain C.
> > @@ -53,12 +54,28 @@
> >  EXTERN_C_BEGIN
> >  extern PetscErrorCode MatGetFactor_seqaij_petsc(Mat,MatFactorType,Mat*);
> >  EXTERN_C_END
> Use this instead:
> PETSC_EXTERN PetscErrorCode
> > @@ -404,12 +417,119 @@
> Isn't this a lot of blank lines?
> > +#undef __FUNCT__
> > +#define __FUNCT__ "MatSeqAIJCUSPARSEBuildICCTriMatrices"
> > +PetscErrorCode MatSeqAIJCUSPARSEBuildICCTriMatrices(Mat A)
> Please use 'static' if the function is really only used in this one
> file. This identifier is more than 31 characters, thus too long for a
> public symbol.
> > +  Mat_SeqAIJ                   *a                  =
> (Mat_SeqAIJ*)A->data;
> > +  Mat_SeqAIJCUSPARSETriFactors *cusparseTriFactors =
> (Mat_SeqAIJCUSPARSETriFactors*)A->spptr;
> > +  GPU_Matrix_Ifc               * cusparseMatLo       =
> (GPU_Matrix_Ifc*)cusparseTriFactors->loTriFactorPtr;
> > +  GPU_Matrix_Ifc               * cusparseMatUp       =
> (GPU_Matrix_Ifc*)cusparseTriFactors->upTriFactorPtr;
> Either line up consecutive lines or don't, but don't go half way. PETSc
> style guide says 'type *ptr', not 'type * ptr'.
> > +  cusparseStatus_t             stat;
> > +  PetscErrorCode               ierr;
> > +  PetscInt                     *AiUp, *AjUp;
> > +  PetscScalar                  *AAUp;
> > +  PetscScalar                  *AALo;
> > +  PetscInt          nzUpper=a->nz,n=A->rmap->n,i,offset,nz,j;
> > +  Mat_SeqSBAIJ      *b = (Mat_SeqSBAIJ*)A->data;
> > +  const PetscInt    *ai=b->i,*aj=b->j,*vj;
> > +  const MatScalar   *aa=b->a,*v;
> Again, line up or don't line up.
> > +      /* set this flag ... for performance logging */
> > +      ((Mat_SeqAIJCUSPARSETriFactors*)A->spptr)->isSymmOrHerm =
> PETSC_TRUE;
> Does this have a MatSetOption() interface?
> >  #undef __FUNCT__
> >  #define __FUNCT__ "MatSeqAIJCUSPARSEICCAnalysisAndCopyToGPU"
> >  PetscErrorCode MatSeqAIJCUSPARSEICCAnalysisAndCopyToGPU(Mat A)
> This can have static linkage, right?
> > @@ -706,8 +848,28 @@
> >        ierr = MPI_Comm_size(PETSC_COMM_WORLD,&size);CHKERRQ(ierr);
> [Different patch] PETSC_COMM_WORLD cannot be used outside of global
> registration.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130309/a40e93d8/attachment.html>
