[petsc-dev] refactoring petsccusp.h needed
Paul Mullowney paulm at txcorp.com
Fri Mar 8 16:07:09 CST 2013
Not quite. I want to expose a PetscScalar * rather than a CUSPARRAY *.
>> 1) I would like a public method that exposes the GPU device pointers to the user. For example, we have VecGetArrayRead(). But, this gives a CPU pointer (which in turn causes a memcpy from CPU to GPU).  We need something that returns the GPU device pointer. This is useful for embedded PETSc solves in external apps that want to use the GPU.
>    Yup. Are these not just
> #undef __FUNCT__
> #define __FUNCT__ "VecCUSPGetArrayReadWrite"
> PETSC_STATIC_INLINE PetscErrorCode VecCUSPGetArrayReadWrite(Vec v, CUSPARRAY **a)
>    PetscErrorCode ierr;
>    PetscFunctionBegin;
>    *a   = 0;
>    ierr = VecCUSPCopyToGPU(v);CHKERRQ(ierr);
>    *a   = ((Vec_CUSP*)v->spptr)->GPUarray;
>    PetscFunctionReturn(0);
> and friends? Just make them not static inline and put the prototypes for them in petsccusp.h  The function call cost can be lived with.
> (You would make them not static inline because we don't want Vec_CUSP to be public.)
> Thanks
>      Barry
>     Barry
>> 2) As for other things. I have a patch for ICC that I'm nearly finished with. After that, I'm going to try to harden the other CUSP preconditioners so that they work with the CUSP and CUSPARSE classes.
>> -Paul
>>>     Do you think you can make that change and anything else that needs doing before the release?
>>>     Thanks
>>>      Barry
