[petsc-dev] can we get rid of SNESCreate_Test() now?
Thu Mar 7 10:22:53 CST 2013
On Thu, Mar 7, 2013 at 10:00 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Thu, Mar 7, 2013 at 8:44 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>    And merged with the  SNESUpdateCheckJacobian() which is not as
>> extensive as the "compare" test but far better designed and much prettier
>> code :-) Also could all that code be pulled out of SNESComputeJacobian()
>> and put in a separate private routine called by SNESComputeJacobian()?
> I see snes->ops->update in all the solvers, including those that do not
> compute Jacobians. Can those calls be moved inside SNESComputeJacobian()?
> If SNESUpdateCheckJacobian continues to be called before computing the
> Jacobian, then it should finish by re-evaluating the residual at the
> original point. Why? Because we allow people to cache part of the Jacobian
> internally and (especially for non-smooth problems) we need to ask the user
> for the Jacobian at exactly the same place we evaluated the residual.
> Do we need this SNESSetUpdate() system for anything else?
My memory is that I put this in there to mimic SNESVI type of things a
decade before that existed.
I had to project things back onto the particles at the end of a step, and I
think I also used it to splice
in a lubrication model.
  Matt
   I object to -snes_compare because it sounds like you are comparing
>> SNESes, which you are not. Maybe -snes_jacobian_compare ?
> I'm happy to use -snes_jacobian_check (or -snes_check_jacobian, depending
> on our endianness).
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130307/5ea2ebc3/attachment.html>
