[petsc-dev] Commit collision/corruption?
Sean Farley sean at mcs.anl.gov
Wed Mar 6 17:10:21 CST 2013
On Wed, Mar 6, 2013 at 5:05 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Wed, 6 Mar 2013, Jed Brown wrote:
>> On Wed, Mar 6, 2013 at 4:54 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
>> > Hmm, maybe this is just the same commit applied to different branches?
>> > (You probably checked
>> > https://bitbucket.org/petsc/**petsc-dev/commits/all/<https://bitbucket.org/petsc/petsc-dev/commits/all/>already?)
>> > One seems to be applied to the 'yellow branch', the other to the 'blue
>> > branch'.
>> The color is not significant. Neither commit has a named branch associated
>> with it.
>> (Hg branches are like labels in the sense that you can have several heads
>> that are all part of the same named "branch".)
> The empty 'diffs' is interesting. It happens with 'rebase of a merge'
> [for some hg versions or all hg version?]  But then this is a merge
> commit [not a rebase commit]. And then Barry doesn't use rebase..
> So my suspession is - BitBucket doing someting funky for a commit that
> got pushed via 2 diffrent routes.
Who did the rebasing? Which version of mercurial? Jed, was this
through your gitifyhg extension?
