[petsc-dev] Some questions about adding default global to local, etc., functions for DMShell
Richard Tran Mills rtm at eecs.utk.edu
Wed Mar 6 13:54:39 CST 2013
Hi Folks,
I am adding some pointers to scatter contexts within the internal "data"
struct for DMShell, e.g. the 'gtol' and 'ltog' members in
typedef struct  {
   Vec Xglobal;
   Vec Xlocal;
   Mat A;
   VecScatter *gtol;
   VecScatter *ltog;
} DM_Shell;
First question: When in DMCreate_Shell we do
ierr     = PetscNewLog(dm,DM_Shell,&shell);CHKERRQ(ierr);
will this guarantee that gtol and ltog are set to NULL, or do I need to
explicitly set these somewhere?  I see that the allocated memory is
zeroed but I'm not sure how NULL might actually be represented in memory.
I have also added some new functions like
DMShellDefaultGlobalToLocalBegin()/End(), and in DMCreate_Shell I do
   dm->ops->globaltolocalbegin = DMShellDefaultGlobalToLocalBegin;
   dm->ops->globaltolocalend   = DMShellDefaultGlobalToLocalEnd;
The user can set different routines via
DMShellSetGlobalToLocalBegin()/End(), but if the user only sets the gtol
and ltog scatter contexts, then the default routines will perform the
appropriate scatter operations.
Second question: What is the proper "PETSc way" to throw an error if
gtol is NULL and tell the user that DMShellDefaultGlobalToLocalBegin()
cannot be used without first setting the scatter context via
DMShellSetGlobalToLocalVecScatter()?
Richard
Richard Tran Mills, Ph.D.
Computational Earth Scientist      | Joint Assistant Professor
Hydrogeochemical Dynamics Team     | EECS and Earth & Planetary Sciences
Oak Ridge National Laboratory      | University of Tennessee, Knoxville
E-mail: rmills at ornl.gov  V: 865-241-3198 http://climate.ornl.gov/~rmills
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130306/3b8c48c8/attachment.html>
