[petsc-dev] meaning of PETSC_USE_EXTERN_CXX?
Tue Mar 5 18:35:05 CST 2013
On Tue, Mar 5, 2013 at 6:28 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    Ok, and this will still support all four cases above. How do we do
> that? And would it simplify the mess we have now?
We just take the PETSC_USE_EXTERN_CXX branch everywhere so that if
defined(__cplusplus), we always use extern "C" (independent of how PETSc
was configured). This also gets rid of PETSC_EXTERN_C and PETSC_INTERN_C,
leaving only PETSC_EXTERN and PETSC_INTERN.
> > We don't use overloading (PetscPolymorphic* was removed last spring) so
> I don't think there is any functional reason to mangle symbols. AFAICT, the
> only functional reason for building PETSc with a C++ compiler is to use C++
> complex
>    Yes, if a C++ programmer is using PETSc and complex numbers this is a
> legitimate case
> > (and perhaps because the C++ compiler catches different errors than the
> C compiler).
>   Yes, this is a legitimate use of our testing PETSc regularly with C++.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130305/2f72c16d/attachment.html>
