[petsc-dev] make -j not supported? Why???
Sat Mar 2 21:29:12 CST 2013
On Mar 2, 2013, at 3:49 PM, Karl Rupp <rupp at mcs.anl.gov> wrote:
> Hi,
>>    It is possible, but you cannot specify nvcc as CMAKE_CXX_COMPILER,
>>    but instead the script is doing some magic hackery replacing the
>>    C++-compiler with nvcc if the file extension is .cu.
>>    (I consider this to be a hack rather than a clean solution, but
>>    that's the status quo)
>> Yeah, we've discussed this a few times before. FindCUDA.cmake is a total
>> hack and it always looked to me like trying to use it would cause other
>> conflicts, but perhaps not.
> We can give it a try. Since we use the .cu-extension, it should work fine. I've once tried to integrate nvcc with CMake to compile CUDA-code in .cpp-files, and this is where things get really bad.
>> CMake's stupid design does not let you add proper languages from
>> cmake-script, and since very few community members write C++ for CMake,
>> it's not surprising that it was hacked up in cmake-script. Now that the
>> hack exists, Kitware is using it as an excuse to not bother doing it right.
> Agree. I think I should finally file a bug report at Kitware about nvcc failing to be recognized as a C++ compiler. Not that I expect any reaction, but I want to make sure they are aware of the issue.
   Yes, so they can list it in their bug tracking system, because that is what bug tracking systems are for.
   Barry
> Best regards,
> Karli
