[petsc-dev] Diff between DMCreate_Xxx and DMXxxCreate?
Tim Tautges tautges at mcs.anl.gov
Fri Mar 1 14:45:58 CST 2013
I see both versions for Plex.  DMPlexCreate seems to create a more "bare" object, while DMCreate_Plex has more
initialization, and the latter is what's registered in dmregall.c.  Are both versions necessary, for different settings?
- tim
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
