[petsc-dev] should this be moved now?
Fri Mar 1 10:25:00 CST 2013
On Mar 1, 2013, at 6:39 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Thu, Feb 28, 2013 at 3:17 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>    With the introduction of PetscPowRealInt() should this be moved to petscmath.h and renamed ?
> We can just replace calls to this function with calls to PetscPowRealInt().
   Note that in these calls the first argument is a PetscScalar in the code. Are these all real values stored in a PetscScalar so PetscRealPart() could be called on them?
  Barry
> /* C++ does not promote int64_t to scalar or int32_t for std::pow() */
> static PetscScalar Pow(PetscScalar b,PetscInt p)
>   return PetscPowScalar(b,(int)p);
