[petsc-dev] confusing download instructions
Sat Jun 29 00:39:53 CDT 2013
On Fri, 28 Jun 2013, Barry Smith wrote:
>   Satish,
>     Ok then for now change the download instructions from
>     The latest stable version can also be downloaded using Git with the following command:
> git clone -b maint https://bitbucket.org/petsc/petsc petsc
>    to
> The patched release can also be downloaded using Git with the following command:
I've updated the text to read:
The release with patches can also be downloaded using Git with the following command:
https://bitbucket.org/petsc/petsc/commits/38733cf246992414f62ee0829b9f1dabe24d155b
Satish
