[petsc-dev] moab nightlybuild failure
Fri Jun 28 17:59:47 CDT 2013
Satish Balay <balay at mcs.anl.gov> writes:
> Not if the branch is rebased [and later garbage collected] - which can
> happen with all working brances [but not master/maint]
Rebasing is not allowed once someone _depends_ on your commit.  Pointing
another project at a commit is a dependency.
You can break anything, but the commit should live if another project is
being pointed at it.  One exception is if the branch is _rejected_ (not
merged to 'master'), but then the downstream package obviously needs to
adapt.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130628/74cb51be/attachment.sig>
