[petsc-dev] moab nightlybuild failure
Fri Jun 28 14:06:08 CDT 2013
Satish Balay <balay at mcs.anl.gov> writes:
> sure - hence my assertion that similar functionality could be
> imlemented with tarballs [with the caveal of using unique urls]
The difference is that you have to cache the URL that was unpacked into
the (global) externalpackages.  Consider that the user could have built
with a different PETSC_ARCH in between.  I suppose this could be done by
writing a hidden .downloadurl file into the package directory after
unpacking.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130628/c69e729c/attachment.sig>
