[petsc-dev] moab nightlybuild failure
Thu Jun 27 17:45:36 CDT 2013
Satish Balay <balay at mcs.anl.gov> writes:
> Ok - fixed in 'balay/fix-moab-git'. Any comments?
> https://bitbucket.org/petsc/petsc/commits/1f16e75d68ca70d003ea3ef4dde0f67dcfe822d6
Looks okay.  What is the recommended way to _not_ try to use the Git
version?  Pass the URL directly?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130627/6278fb72/attachment.sig>
