[petsc-dev] windows fixes.
Wed Jun 26 18:27:40 CDT 2013
Satish Balay <balay at mcs.anl.gov> writes:
> one more issue:
> looks like 2a571ffb5945aee713990b6770e04534a0423780 is not python-2.4 compliant.
> from  configure_next_arch-linux-gcc-absoft_churn.log
Damn, I checked that decorators were used elsewhere, but didn't actually
test with python-2.4.  I now see that the other instances were not in
essential code.
  $ git grep '^\s*@' config
  config/BuildSystem/config/setCompilers.py:  @staticmethod
  config/BuildSystem/config/setCompilers.py:  @config.memoize
  config/BuildSystem/patch.py:      @property
  config/builder.py:  @staticmethod
  config/builder.py: @property
Should these other uses of decorators be replaced with the more clumsy
syntax?  Or is it time to add --download-python?
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130626/fb38a5c0/attachment.sig>
