[petsc-dev] [petsc-maint] Updating PETSc to support Elemental 0.80
Sean Farley sean.michael.farley at gmail.com
Tue Jun 25 15:00:51 CDT 2013
Jack Poulson writes:
> On Mon, Jun 24, 2013 at 11:56 AM, Satish Balay <balay at mcs.anl.gov> wrote:
>> > If I am to have Clique build on top of pkg-metis and pkg-parmetis, I will
>> > need to modify them to install enough header files so that it can make
>> use
>> > of metislib.h and parmetislib.h.
>> So clique requires additional include files? I supporse these are
>> private include files from metis/parmetis..
> Yes, I wanted nodal bisection routines, and (par)metis only provides a
> restrictive nested dissection routine. I therefore implemented sequential
> and parallel versions using metis and parmetis's internal APIs. See
> https://github.com/poulson/Clique/blob/master/src/metis/Bisect.c
> and
> https://github.com/poulson/Clique/blob/master/src/parmetis/ParallelBisect.c
>> >  I'll try to propose a patch over the next
>> > few days and include the 'include_directories(headers)' and replace the
>> > strange 'include(FindMpi); if(NOT MPI_FOUND)' statements with guarded
>> > 'find_package(MPI); if(NOT MPI_C_FOUND)' statements.
>> Looks like that piece of code is from upstream. It has the comment:
>> # GK commented this out as it seems to be creating problems
> Agreed. But the reason it is commented out might be because of incorrect
> usage of the CMake script. From the point of view of someone just trying to
> build parmetis, it helps to have it there (whether optional or not).
Jack,
I can't guarantee I'll work on this soon but since I need to update
metis / parmetis in macports, I will eventually be dealing with the
cmake issues you've brought up. For the next week or two, I'm pretty
busy but I'll try to find some time soon.
