[petsc-dev] code review request : txpetscgpu package removal
Paul Mullowney paulm at txcorp.com
Tue Jun 25 14:43:34 CDT 2013
I've been refactoring some pieces of PETSc to remove the txpetscgpu
dependence by bringing that code directly into petsc.  All of the
capability in that package only depends on CUDA (and thrust), thus there
is no need for an external package. I think removing this package is an
improvement to the PETSc GPU capabilities as all the code is now easily
visible (i.e. not hidden in some package).
The new code is in the fork:
pmullowney/txpetscgpu-package-removal.git
This branch builds and run on a machine with CUDA/Thrust/CUSP (i.e. no
need for --download-txpetscgpu). However, txpetscgpu has not been
entirely removed yet as there are still some dependencies in the aijcusp
matrix and cusp preconditioner classes.
I would like to start a discussion on the changes I have made which
primarily affect aijcusparse, mpiaijcusparse, and veccusp. There are two
commits that need to be reviewed:
(1)
https://bitbucket.org/pmullowney/txpetscgpu-package-removal/commits/d958d7291a1c03bca66b61ff38ec3bf7cd177769
(2)
https://bitbucket.org/pmullowney/txpetscgpu-package-removal/commits/263367a00e0a4a32cfef67c220c1904473582547
I think (1) should be reviewed first as this adds most of the serial GPU
capability to aijcusparse. The second commit (2) adds changes to veccusp
and mpiaijcusparse to get an efficient multi-GPU SpMV.
Should I submit a pull request?
-Paul
