[petsc-dev] FieldSplit SetUp
Wed Jun 19 10:28:05 CDT 2013
Matthew Knepley <knepley at gmail.com> writes:
> When we call PCSetUp() on a FieldSplit, it does not call SetUp() on its
> subsolves. Is this deliberate? It is making it hard to test a MF MG on the
> A11 of a fieldsplit.
I don't know what was intended, but it's a problem to set everything up
when the inner solves will fail (e.g., bad pivot) without getting them
out to set other options.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130619/bc1ba02e/attachment-0001.sig>
