[petsc-dev] Who fucked up the repository?
Sat Jun 15 15:23:51 CDT 2013
I get this every time I try to push a branch:
git -c diff.mnemonicprefix=false -c core.quotepath=false push -v --tags
origin knepley/pylith:knepley/pylith
Pushing to git at bitbucket.org:petsc/petsc
To git at bitbucket.org:petsc/petsc
 = [up to date]      v2.0.29 -> v2.0.29
 = [up to date]      v2.1.0 -> v2.1.0
 = [up to date]      v2.3.2 -> v2.3.2
 = [up to date]      v2.3.3 -> v2.3.3
 = [up to date]      v3.0.0 -> v3.0.0
 = [up to date]      v3.1 -> v3.1
 = [up to date]      v3.2 -> v3.2
 = [up to date]      v3.3 -> v3.3
 = [up to date]      v3.4 -> v3.4
   3d2e007..e4fc00d  knepley/pylith -> knepley/pylith
 ! [rejected]        v3.4.1 -> v3.4.1 (non-fast-forward)
updating local tracking ref 'refs/remotes/origin/knepley/pylith'
error: failed to push some refs to 'git at bitbucket.org:petsc/petsc'
hint: Updates were rejected because a pushed branch tip is behind its remote
hint: counterpart. Check out this branch and merge the remote changes
hint: (e.g. 'git pull') before pushing again.
hint: See the 'Note about fast-forwards' in 'git push --help' for details.
Completed with errors, see above
If I remove --tags, then it works.
   Matt
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130615/b7599dc3/attachment.html>
