[petsc-dev] making tarball of knepley/pylith branch
Brad Aagaard baagaard at usgs.gov
Fri Jun 14 14:56:29 CDT 2013
Satish,
For some reason I added --with-sowing=0 in my customized builddist
script. Obviously that prevented the fortran stubs from being created.
I have things working now. Thanks for your help!
Brad
On 06/14/2013 12:04 PM, Satish Balay wrote:
> On Fri, 14 Jun 2013, Brad Aagaard wrote:
>> Satish,
>> When I use the tarball of the knepley/pylith branch that I generated it looks
>> like I am missing all of the fortranstubs. Configure and make proceed, but the
>> first 'make test' fails due to missing symbols.
>> The link of the test fails:
>> /home/brad/tmp/petsc-pylith/arch-gcc-4.6.1_debug/lib/libpetsc.so: undefined
>> reference to `kspfgmresmodifypcksp_'
>> reference to `kspfgmresmodifypcnochange_'
>> reference to `tsmonitordefault_'
>> I noticed that the builddist script runs "make allfortransubs" and the tarball
>> excludes bin/maint. Where are the fortran stubs supposed to be in the
>> resulting tarball?
> in ftn-auto subdir of the corresponding source dir. i.e
> src/ksp/ksp/impls/gmres/fgmres/ftn-auto/modpcff.c
> src/ts/interface/ftn-auto/tsf.c
> Satish
>> Thanks,
>> Brad
>> On 06/14/2013 09:34 AM, Satish Balay wrote:
>>> On Fri, 14 Jun 2013, Satish Balay wrote:
>>>> On Thu, 13 Jun 2013, Brad Aagaard wrote:
>>>>> In the past I have used the nightly tarball of petsc for our PyLith
>>>>> releases.
>>>>> Matt created a knepley/pylith branch that we now use with PyLith. I want
>>>>> to
>>>>> create a tarball analogous to the nightly tarball for the knepley/pylith
>>>>> branch for our upcoming PyLith release.
>>>> you could do: bin/maint/builddist knepley/pylith
>>> That should be: bin/maint/builddist $PETSC_DIR knepley/pylith
>>> nd looks like I need to fixup the script to convert knepley/pylith to
>>> knepley-pylith [otherwise the script will attempt to generate
>>> ~/petsc-knepley/pylith.tar.gz :(
>>> satish
>>>>> I found the builddist script in $PETSC_DIR/bin/maint but it seems to
>>>>> mess with
>>>>> my current repo (cleaning, etc) and wants to configure with matlab
>>>>> enabled.
>>>>> Should I make a clean clone for building the tarball?
>>>> Yes I spin tarballs form a separate/clean repo.
>>>> Since the script was written to not add in superflus stuff into
>>>> release tarballs - it attempts to do a thorough 'clean' of the build
>>>> tree.
>>>>> What is the recommended
>>>>> procedure for customizing the configure options in builddist (the
>>>>> cleaning
>>>>> removes any changes I make) so that I get a tarball but don't need extra
>>>>> packages like matlab and c2html?
>>>> Hm - I don't think its possible to switch that off from configure
>>>> [without some modifications]
>>>> I can spin a nightly tarball for knepley/pylith and place it at the
>>>> petsc ftp site - if that would be useful.
>>>> Satish
