[petsc-dev] making tarball of knepley/pylith branch
Brad Aagaard baagaard at usgs.gov
Fri Jun 14 12:44:41 CDT 2013
Satish,
Thanks for the info. We need a tarball only a few times a year, so I
think it will be easiest if I just customize the builddist script for
our needs. This way I can run configure without matlab, etc. I already
fixed the conversion from knepley/pylith to knepley-pylith.
Brad
On 06/14/2013 09:34 AM, Satish Balay wrote:
> On Fri, 14 Jun 2013, Satish Balay wrote:
>> On Thu, 13 Jun 2013, Brad Aagaard wrote:
>>> In the past I have used the nightly tarball of petsc for our PyLith releases.
>>> Matt created a knepley/pylith branch that we now use with PyLith. I want to
>>> create a tarball analogous to the nightly tarball for the knepley/pylith
>>> branch for our upcoming PyLith release.
>> you could do: bin/maint/builddist knepley/pylith
> That should be: bin/maint/builddist $PETSC_DIR knepley/pylith
> nd looks like I need to fixup the script to convert knepley/pylith to
> knepley-pylith [otherwise the script will attempt to generate
> ~/petsc-knepley/pylith.tar.gz :(
> satish
>>> I found the builddist script in $PETSC_DIR/bin/maint but it seems to mess with
>>> my current repo (cleaning, etc) and wants to configure with matlab enabled.
>>> Should I make a clean clone for building the tarball?
>> Yes I spin tarballs form a separate/clean repo.
>> Since the script was written to not add in superflus stuff into
>> release tarballs - it attempts to do a thorough 'clean' of the build
>> tree.
>>> What is the recommended
>>> procedure for customizing the configure options in builddist (the cleaning
>>> removes any changes I make) so that I get a tarball but don't need extra
>>> packages like matlab and c2html?
>> Hm - I don't think its possible to switch that off from configure
>> [without some modifications]
>> I can spin a nightly tarball for knepley/pylith and place it at the
>> petsc ftp site - if that would be useful.
>> Satish
