[petsc-dev] Remove or deprecate DMDALocalToLocalBegin/End when adding DMLocalToLocalBegin/End
Thu Jun 13 02:48:00 CDT 2013
Richard Tran Mills <rtm at eecs.utk.edu> writes:
> Hi Folks,
> Another question related to adding DMLocalToLocalBegin()/End(): When I do
> so, the existing DMDALocalToLocalBegin()/End() become redundant.  Should
> these DMDA routines be removed, or is there some mechanism in place to
> mark them as deprecated or similar these days?
You can deprecate gently like this:
PETSC_DEPRECATED("Use DMLocalToLocalBegin()") PETSC_EXTERN PetscErrorCode DMDALocalToLocalBegin(DM,Vec,InsertMode,Vec);
