[petsc-dev] Very Small Patch for aijcusparse class
Karl Rupp rupp at mcs.anl.gov
Sat Jun 8 10:16:32 CDT 2013
Hi Paul,
the changes go through at least one run of nightly tests. If everything
passes, then it will be merged to master and locally tested again. I did
so for your patch just now, so it's now in master. :-)
Best regards,
Karli
On 06/07/2013 12:35 PM, Paul Mullowney wrote:
> Thanks Karl,
> When do changes in next get pushed to master?
> -Paul
>> Hi Paul,
>> thanks for the patch, I pushed it into next and also updated the
>> commit message slightly to have a more expressive one-line summary:
>> https://bitbucket.org/petsc/petsc/commits/404133a2edbeb3467ebbc93177d4d43594f51dec
>> Best regards,
>> Karli
>> On 06/06/2013 12:42 PM, Paul Mullowney wrote:
>>> Hi,
>>> This patch fixes some small valgrind errors I was seeing in this class.
>>> Let me know if there are any issues. Tests related to the aijcusparse
>>> class pass (on master) after this patch.
>>> Thanks,
>>> -Paul
