[petsc-dev] Experimental GNU make build system
Thu Jun 6 16:11:35 CDT 2013
On Wed, 5 Jun 2013, Satish Balay wrote:
> BTW: should we move kspams.c into a subdir [srcksp/ksp/interface/ams]
> - so that its conditionally compiled?  [or add in a dummy code at the
> end of the current #ifdef in code]. This could go into maint
fixed in 'balay/fix-kspams-build-warning' and merged to next.
Satish
> balay at msnehalem2 ~/petsc.clone
> $ make -f gmakefile PETSC_ARCH=arch-cmplx -j 20 V=1
> /home/balay/petsc.clone/bin/win32fe/win32fe lib -a /home/balay/petsc.clone/arch-cmplx/lib/libpetsc.lib @/home/balay/petsc.clone/arch-cmplx/lib/libpetsc.lib.args
> kspams.o : warning LNK4221: no public symbols found; archive member will be inaccessible
> /usr/bin/true /home/balay/petsc.clone/arch-cmplx/lib/libpetsc.lib
