[petsc-dev] need metis/parmetis upgrade
Thu Jun 6 16:09:54 CDT 2013
Satish Balay <balay at mcs.anl.gov> writes:
> I have a backup copy of all the repos from http://petsc.cs.iit.edu/petsc now at (mcs):
> ~petsc/petsc.cs.iit.edu-hg-petsc-backup
> metis is at: ~petsc/petsc.cs.iit.edu-hg-petsc-backup/externalpackages/metis-5.0.2
https://bitbucket.org/petsc/pkg-metis
I figure that 5.0.3 should be applied on the 'upstream' branch and
merged to 'master'.
