[petsc-dev] HDF5 Viewer for Fortran 90
Mon Jun 3 16:04:51 CDT 2013
Chris,
Thanks for the confirmation. Its in next now - and will add to
master/mainter later.
Satish
On Mon, 3 Jun 2013, Chris Eldred wrote:
> Hey Satish,
> Everything seems to be working fine with HDF5 bindings for Fortran now.
> I'll let you guys know if I run into any other problems!
> -Chris
> On Thu, May 30, 2013 at 1:43 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > I pused the fix in the branch balay/hdf5-ftnbinding. But since this is
> > off 'maint/3.4' - you can do the following to use it with petsc-dev.
> > # checkout origin/master in detached mode - so that it can be discarded
> > later
> > git fetch origin
> > git checkout origin/master
> > git merge origin/balay/hdf5-ftnbinding
> > make allfortranstubs
> > make
> > Let us know if it works.
> > thanks,
> > Satish
> > > > Looks like we need custom bindings for
> > > > PetscErrorCode  PetscViewerHDF5PushGroup(PetscViewer viewer, const
> > char *name)
> > > > PetscErrorCode  PetscViewerHDF5GetGroup(PetscViewer viewer, const char
> > **name)
> > > > Will take a look.
> > > > Fortran bindings don't make sense for these two?
> > > > PetscErrorCode  PetscViewerHDF5Open(MPI_Comm comm, const char name[],
> > PetscFileMode type, PetscViewer *hdf5v)
> > > I see we already have a  custom binding for this one
> > > Satish
> > > > PetscErrorCode  PetscViewerHDF5GetFileId(PetscViewer viewer, hid_t
> > *file_id)
> > > > Satish
> > > > On Wed, 29 May 2013, Barry Smith wrote:
> > > > >    Satish,
> > > > >      Please branch off of maint and get them all into the next patch
> > (as well as master) if Jed hasn't done this.
> > > > >    Barry
> > > > > On May 29, 2013, at 3:29 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> > > > > > Chris Eldred <chris.eldred at gmail.com> writes:
> > > > > >> I am having issues getting the HDF5 Viewer to work with Fortran
> > 90.
> > > > > >> Specifically, I get the following types of errors when attempting
> > to link
> > > > > >> my executable together:
> > > > > >> /home/user/Dropbox/NTM/SIEVETEST/OPERATOR/src/output.f90:664:
> > undefined
> > > > > >> reference to `petscviewerhdf5settimestep_'
> > > > > >> /home/user/Dropbox/NTM/SIEVETEST/OPERATOR/src/output.f90:668:
> > undefined
> > > > > >> reference to `petscviewerhdf5pushgroup_'
> > > > > >> /home/user/Dropbox/NTM/SIEVETEST/OPERATOR/src/output.f90:675:
> > undefined
> > > > > >> reference to `petscviewerhdf5popgroup_'
> > > > > >> It seems like the Fortran interfaces for the HDF5-specific viewer
> > functions
> > > > > >> are not present (there are no issues with the other viewer
> > functions).
> > > > > > Yes, PetscViewerHDF5PushGroup() needs a custom binding.  The
> > others can
> > > > > > be auto-generated.
