[petsc-dev] Segfault in DMPlexDistribute
Chris Eldred chris.eldred at gmail.com
Wed Jul 31 16:41:13 CDT 2013
I wrapped DMPlexCreateFromCellList so that only rank 0 executes it, now I
get this new error for np >= 2 (still works fine with np=1). The new error
is:
[1]PETSC ERROR: --------------------- Error Message
[1]PETSC ERROR: Invalid argument!
[1]PETSC ERROR: Wrong type of object: Parameter # 1!
[1]PETSC ERROR:
[1]PETSC ERROR: Petsc Development GIT revision:
dd831807ccae33b4bba0c6456b55575ff17239c3  GIT Date: 2013-06-03 14:26:06
-0600
[1]PETSC ERROR: See docs/changes/index.html for recent updates.
[1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[1]PETSC ERROR: See docs/index.html for manual pages.
[1]PETSC ERROR:
[1]PETSC ERROR: ./test on a arch-linux2-cxx-debug named Puget-101334 by
user Wed Jul 31 16:37:07 2013
[1]PETSC ERROR: Libraries linked from
/home/user/Desktop/LIBRARIES/petsc/arch-linux2-cxx-debug/lib
[1]PETSC ERROR: Configure run at Mon Jun  3 14:29:12 2013
[1]PETSC ERROR: Configure options --download-boost --download-chaco
--download-ctetgen --download-f-blas-lapack --download-fiat
--download-generator --download-hdf5 --download-metis --download-ml
--download-mpich --download-parmetis --download-scientificpython
--download-triangle --with-clanguage=cxx --with-dynamic-loading
--with-openmp --with-pthreadclasses --with-shared-libraries --with-sieve
--with-threadcomm PETSC_ARCH=arch-linux2-cxx-debug
[1]PETSC ERROR:
[1]PETSC ERROR: DMPlexDistribute() line 2772 in
/home/user/Desktop/LIBRARIES/petsc/src/dm/impls/plex/plex.c
Should I be doing some sort of collective instantiation on dm or dm_distrib
before I attempt to distribute dm? I tried adding
call DMPlexCreate(PETSC_COMM_WORLD, dm, ierr)
CHKERRQ(ierr)
before the call to DMPlexCreateFromCellList but then the code just hangs
for np >= 2 (again np=1 is fine).
A complete test code is below:
program test
implicit none
#include <finclude/petsc.h90>
DM :: dm, dm_distrib
PetscViewer :: viewer
PetscErrorCode :: ierr
PetscInt :: rank
PetscInt, dimension(6) :: cell_list
PetscReal, dimension(8) :: vertex_coords
call PetscInitialize(PETSC_NULL_CHARACTER,ierr)
CHKERRQ(ierr)
call MPI_Comm_rank(PETSC_COMM_WORLD,rank,ierr)
CHKERRQ(ierr)
cell_list = (/ 0 , 1 , 2  , 1 , 3 , 2 /)
vertex_coords = 0.0
!call DMPlexCreate(PETSC_COMM_WORLD, dm, ierr)
!CHKERRQ(ierr)
if (rank==0) then
call DMPlexCreateFromCellList(PETSC_COMM_WORLD, 2, 2, 4, 3,  1 , cell_list
, 2 , vertex_coords , dm,  ierr)
CHKERRQ(ierr)
end if
call DMPlexDistribute(dm,'chaco',1,dm_distrib,ierr)
CHKERRQ(ierr)
call PetscFinalize(ierr)
CHKERRQ(ierr)
end program test
-Chris
On Wed, Jul 31, 2013 at 4:21 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> Chris Eldred <chris.eldred at gmail.com> writes:
> > Here is my relevant code:
> > vertex_coords = 0.0
> cell_list
> > CHKERRQ(ierr)
> Which process executes this line?  DMPlexDistribute expects rank 0 to
> hold the mesh to be distributed.  If this doesn't fix the problem, can
> you send a test code so we can debug and add it to our test suite?
> > call DMPlexDistribute(dm,'chaco',0,dm_distrib,ierr)
> > CHKERRQ(ierr)
> > I am running the code with mpirun -np 2 ./test (it also segfaults with
> > higher values for np).
> > Any ideas? The code works fine with mpirun -np 1 (presumably since it is
> > not actually attempting to distribute the mesh).
Chris Eldred
DOE Computational Science Graduate Fellow
Graduate Student, Atmospheric Science, Colorado State University
B.S. Applied Computational Physics, Carnegie Mellon University, 2009
chris.eldred at gmail.com / celdred at atmos.colostate.edu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130731/a875eb3a/attachment.html>
