[petsc-dev] Improving and stabilizing GPU support
Nystrom, William D wdn at lanl.gov
Fri Jul 19 15:21:03 CDT 2013
Hi Karli,
Your list sounds great to me.  Glad that you and Paul are working on this together.
My main interests are in better preconditioner support and better multi-GPU/MPI
scalability.
Is there any progress on Steve Dalton's work on the cusp algebraic multigrid
preconditioner with PETSc?  I believe Jed said in a previous email that Steve
was going to be working on adding MPI support for that as well as other
enhancements.
Will there be any improvements for GPU preconditioners in ViennaCL 1.5.0?
When do you expect ViennaCL 1.5.0 to be available in PETSc?
I'm also interested in trying the PETSc ViennaCL support on the Xeon Phi.
Do you have a schedule for when that might be ready for friendly testing?
Dave
Dave Nystrom
LANL HPC-5
Phone: 505-667-7913
Email: wdn at lanl.gov
Smail: Mail Stop B272
       Group HPC-5
       Los Alamos National Laboratory
       Los Alamos, NM 87545
From: petsc-dev-bounces at mcs.anl.gov [petsc-dev-bounces at mcs.anl.gov] on behalf of Karl Rupp [rupp at mcs.anl.gov]
Sent: Friday, July 19, 2013 1:12 PM
To: For users of the development version of PETSc
Subject: [petsc-dev] Improving and stabilizing GPU support
Hi guys,
now as the Paul's pull request for largely removing the txpetscgpu
dependency is merged to next, I will proceed with further improving our
GPU support. My ideas and TODO-list are as follows:
* Reduce CUSP dependency: The current elementary operations are mainly
realized via CUSP. With better support via CUSPARSE and CUBLAS, I'd add
a separate 'native' CUDA backend so that we can provide a full set of
vector and sparse matrix operations out of the default NVIDIA toolchain.
We will still keep CUSP for its preconditioners, yet we no longer depend
on it.
* Integrate last bits of txpetscgpu package. I assume Paul will provide
a helping hand here.
* Better ViennaCL bindings: The OpenCL version of VecMDot() will
experience a boost with the ViennaCL 1.5.0 release, the CUDA version was
fixed a couple of month back. Also, VecCopySome() will get improved in
order to provide better MPI performance (similar to what Paul applied
for CUSPARSE)
* Documentation: Add a chapter on GPUs to the manual, particularly on
what to expect and what not to expect. Update documentation on webpage
regarding installation.
* Integration of FEM quadrature from SNES ex52. The CUDA part requiring
code generation is not very elegant, while the OpenCL approach is better
suited for a library integration thanks to JIT. However, this requires
user code to be provided as a string (again not very elegant) or loaded
from file (more reasonable). How much FEM functionality do we want to
provide via PETSc?
Please don't hesitate to post other GPU wishes. Now it's the best time
for doing so :-)
Best regards,
Karli
