[petsc-dev] [petsc-maint] CUDA Version Compatibility
Fri Jul 19 13:38:51 CDT 2013
On Jul 19, 2013, at 10:47 AM, Matthew Knepley <petsc-maint at mcs.anl.gov> wrote:
> On Fri, Jul 19, 2013 at 10:38 AM, Jason Sarich <sarich at mcs.anl.gov> wrote:
> Shiva,
> This is from my bad merge. PETSc used to allow cuda without cusp/thrust, this is apparently no longer an option. I'll fix this.
> We do. You configure with --with-cuda-only
   In the long run this is a terrible way to indicate this and needs to be changed. It is inconsistent with how we do everything else by simply adding additional supports using --with-xxx.    We should have --with-cuda for basic cuda support and --with-cusp for cusp support (which may automatically add the --with-cuda).
   Barry
>    Matt
> Jason
> On Thu, Jul 18, 2013 at 4:06 PM, Chekuri Choudary <cchoudary at rnet-tech.com> wrote:
> Apparently, I was using a branch that deviated from petsc-dev before this
> got fixed. I am testing the master and will let you know the result. Thank
> you very much.
> -----Original Message-----
> From: Satish Balay [mailto:balay at mcs.anl.gov]
> Sent: Thursday, July 18, 2013 4:56 PM
> To: petsc-maint
> Cc: sarich at mcs.anl.gov; Chekuri Choudary
> Subject: Re: [petsc-maint] CUDA Version Compatibility
> On Thu, 18 Jul 2013, Satish Balay wrote:
> > https://bitbucket.org/petsc/petsc/src/3123b27f26841f5e48c5aadd3e04f879
> > f1d21372/config/PETSc/packages/cuda.py?at=sarich/rnet-all#cl-52
> > 3ae844c2        (Daniel Lowell  2011-10-26 09:17:02 -0500       29)#
> self.ThrustVersionStr = str(int(self.ThrustVersion)/100000) + '.' +
> str(int(self.ThrustVersion)/100%1000) + '.' + str(int(self.ThrustVersio
> > 3ae844c2        (Daniel Lowell  2011-10-26 09:17:02 -0500       30)#
> self.CUSPVersionStr   = str(int(self.CUSPVersion)/100000) + '.' +
> str(int(self.CUSPVersion)/100%1000) + '.' + str(int(self.CUSPVersion)%100)
> ops - I meant to refer to the following lines that got commneted - causing
> configure to give this error.
> 3ae844c2        (Daniel Lowell  2011-10-26 09:17:02 -0500       51) ####
> self.cusp         = framework.require('config.packages.cusp',        self)
> 3ae844c2        (Daniel Lowell  2011-10-26 09:17:02 -0500       52) ####
> self.thrust       = framework.require('config.packages.thrust',      self)
> satish
> > Jason might have to take a look on the rbase?
> > Satish
> > On Thu, 18 Jul 2013, Matthew Knepley wrote:
> > > On Thu, Jul 18, 2013 at 3:24 PM, Chekuri Choudary
> > > <cchoudary at rnet-tech.com>wrote:
> > > > It appears that there is an issue with checkCUDAVersion. I have
> > > > downloaded the most recent versions of both CUSP and THRUST and
> > > > tested with both CUDA
> > > > 4.0 and CUDA 5.0. The configure.log files are attached.
> > > Send $PETSC_DIR/config/PETSc/packages/cuda.py.
> > >     Matt
> > > > Thanks
> > > > Sent: Thursday, July 18, 2013 2:35 PM
> > > > To: Chekuri Choudary
> > > > Cc: petsc-maint at mcs.anl.gov
> > > > CUDA5.0 should work [and perhaps all cuda 4 versions aswell]
> > > > Configure Options: --configModules=PETSc.Configure
> > > > --optionsModule=PETSc.compilerOptions --with-x=1 --CFLAGS="-O3 -g
> > > > -ggdb -fopenmp" --FFLAGS="-O3 -g" --with-batch=0
> > > > --known-mpi-shared-libraries=no
> > > > --with-cuda=1 --CUDAC=nvcc --with-cuda-dir=/usr/local/cuda-5.0/
> > > > PETSC_ARCH=PFLOTRAN1 <<<<
> > > > 'Configure' object has no attribute 'thrust'  File
> > > > "./config/configure.py", line 293, in petsc_configure
> > > >     framework.configure(out = sys.stdout) <<
> > > > Perhaps there should be a better error check somewere. You need
> > > > --with-thrust=1 [which is packaged in cuda] - and also
> > > > --with-cusp=1 [perhaps with appropriate --with-cusp-dir option -
> > > > or installed at '/usr/local/cuda-5.0/include/cusp']
> > > > Check config/examples/arch-cuda-double.py
> > > > Satish
> > > > On Thu, 18 Jul 2013, Chekuri Choudary wrote:
> > > > > Hi,
> > > > > Is it necessary to use CUDA 4.1 or 4.2 to use the GPU
> > > > > capabilities in
> > > > PETSc.
> > > > > I am having problems compiling PETSc with CUDA. I have both
> > > > > CUDA4.0 and
> > > > > CUDA5.0 installed. Please find the configure.log files attached.
> > > > > Thanks
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
