[petsc-dev] Error checking on input only vectors
Karl Rupp rupp at mcs.anl.gov
Tue Jul 16 09:15:55 CDT 2013
Hey,
>     As an extra error checking on user code we could save the Vec state of read only input Vecs and check it on exit of the routine to insure the user has not changed the Vec. This could be done in PCApply_Shell(), functions provided to SNES and TS etc.
we could do that, but I think this would slow the debug build down by
quite a substantial amount (VecGetArrayRead() is used quite a lot
internally as well), resulting in users to go with optimized builds
during the development phase more often. Also, since VecGetArrayRead()
returns a pointer to const, a user needs to cast away the const in order
to manipulate entries, which already serves as an indication of doing
something evil.
What about a second debug level instead, something like
'PETSC_DEBUG_EXTRA', which enables additional, more expensive checks
like the one you suggested? We could do similar valgrind-like checks for
matrices, etc. there.
Best regards,
Karli
> On Jul 16, 2013, at 8:08 AM, Rémi Lacroix <remi.lacroix at inria.fr> wrote:
>> Hello,
>> I'm currently developing a preconditioner using PETSc. I have a small question about the PCApply function.
>> Is it safe to destroy the content of the input vector x while applying the preconditioner or should I make a copy of it and work on that?
>> Best regards,
>> Rémi Lacroix
>> Équipe ALPINES
>> Inria Paris-Rocquencourt / Laboratoire Jacques Louis Lions, UPMC
