[petsc-dev] Fixes for ts/examples/tutorials ex16 and ex21
Patrick Sanan psanan at cms.caltech.edu
Mon Jul 15 11:42:22 CDT 2013
When trying to run two of the TS examples, I saw an error about matrices in the wrong state. Adding MatSetUp as the error messages suggest prevents the error from being thrown. A patch is attached (or I can push a branch and submit a pull request if that's a better way to deal with a small potential fix like this).
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130715/e5c8138c/attachment.obj>
