[petsc-dev] Migrate SLEPc to bitbucket
Tue Jul 9 09:28:30 CDT 2013
"Jose E. Roman" <jroman at dsic.upv.es> writes:
> I don't know. Maybe it is better to have a slepc team account, then I
> would add you as an administrator. Is this ok?
That's fine.  We could also add you as an admin to the PETSc account and
you can have a SLEPc group so that you could manage permissions for
petsc/slepc.git separately from other repositories in our account.
Regardless of which you choose, you may as well grab the
bitbucket.org/slepc and github.com/slepc namespaces in case you ever
want to use them.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130709/b94b5930/attachment.sig>
