[petsc-dev] [Bitbucket] Pull request #62: PCBDDC: bugfix in PCPostSolve_BDDC. (petsc/petsc)
Fri Jul 5 17:09:46 CDT 2013
[Moving to petsc-dev]
Stefano Zampini <pullrequests-reply at bitbucket.org> writes:
> --- you can reply above this line ---
> New comment on pull request:
> https://bitbucket.org/petsc/petsc/pull-request/62/pcbddc-bugfix-in-pcpostsolve_bddc#comment-361980
> Stefano Zampini said:
> I'm on a two days holiday, I will remove function pointers as soon as
> I will come back home (Monday). Then you can merge a complete branch
> with a clean history as you like ;-)
Should I just add the following, or did you have more in mind?
diff --git i/src/ksp/pc/impls/bddc/bddc.c w/src/ksp/pc/impls/bddc/bddc.c
index 14c8718..d56745e 100644
--- i/src/ksp/pc/impls/bddc/bddc.c
+++ w/src/ksp/pc/impls/bddc/bddc.c
@@ -933,7 +933,7 @@ static PetscErrorCode PCBDDCMatFETIDPGetRHS_BDDC(Mat fetidp_mat, Vec standard_rh
   /* change of basis for physical rhs if needed
      It also changes the rhs in case of dirichlet boundaries */
-  (*mat_ctx->pc->ops->presolve)(mat_ctx->pc,NULL,standard_rhs,NULL);
+  ierr = PCPreSolve_BDDC(mat_ctx->pc,NULL,standard_rhs,NULL);CHKERRQ(ierr);
   /* store vectors for computation of fetidp final solution */
   ierr = VecScatterBegin(pcis->global_to_D,standard_rhs,mat_ctx->temp_solution_D,INSERT_VALUES,SCATTER_FORWARD);CHKERRQ(ierr);
   ierr = VecScatterEnd(pcis->global_to_D,standard_rhs,mat_ctx->temp_solution_D,INSERT_VALUES,SCATTER_FORWARD);CHKERRQ(ierr);
@@ -1044,7 +1044,7 @@ static PetscErrorCode PCBDDCMatFETIDPGetSolution_BDDC(Mat fetidp_mat, Vec fetidp
   ierr = VecScatterEnd  (pcis->global_to_D,pcis->vec1_D,standard_sol,INSERT_VALUES,SCATTER_REVERSE);CHKERRQ(ierr);
   /* final change of basis if needed
      Is also sums the dirichlet part removed during RHS assembling */
-  (*mat_ctx->pc->ops->postsolve)(mat_ctx->pc,NULL,NULL,standard_sol);
+  ierr = PCPostSolve_BDDC(mat_ctx->pc,NULL,NULL,standard_sol);CHKERRQ(ierr);
   PetscFunctionReturn(0);
> Maybe I was not clear regarding Pre and Post solves, there's not
> special code (except the if (..) guards) for FETI-DP into
> PCPreSolve_BDDC and PCPostSolve_BDDC; they are needed by the BDDC
> itself when the change of basis has been requested and/or some rows of
> the MATIS matrix has been zeroed out to impose dirichlet
> conditions. More specifically, change of basis is completely
> trasparent to the user: MATIS local matrices are changed during
> presolve and then restored back in postsolve.
I'm not opposed to doing the change of basis in pre/post solve, but I
don't think anyone liked the fragility induced by -ksp_diagonal_scale,
which is the same kind of thing.
> Regarding FETI-DP: the current code (which is working great by the
> way) is built on top of the PCBDDC class and it is still at its
> infancy regarding a fully integration with PETSc and its
> classes. PCPreSolve_BDDC and PCPostSolve_BDDC should be exactly where
> they currently are in FETI-DP code, since FETI-DP context uses the
> BDDC preconditioner (through the private function
> PCBDDCApplyInterfacePreconditioner) to compute Matrix vector
> multiplication in Krylov methods.
I think this tracks off into a discussion that I'd like to get others'
opinions about.  We currently have a very simple PCGalerkin that can
formulate a problem in an alternative space (PCMG can do something
similar and more).  We could have an enhanced version called PCFETIDP
that does this setup for FETI-DP.  I don't consider it acceptable to ask
the user to do anything special for FETI-DP beyond that which is
algorithmically critical (MATIS Neumann matrices).
> We should decide how to definitively embed FETIDP into PETSc; does it
> should be a KSP? What should be the calling sequence for the user to
> build the FETI-DP matrix? Barry? Maybe we should move this to a
> separate thread.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130705/18014d1c/attachment.sig>
