[petsc-dev] Pushing to 'master'
Wed Jul 3 17:48:23 CDT 2013
Hong, you are doing well with the formal workflow, but in this last
round with 'hzhang/mat-cleanup', it looks like you didn't check the
nightly logs before merging (they all failed).
http://ftp.mcs.anl.gov/pub/petsc/nightlylogs/make_next_arch-linux-gcc-ifc_crank.log
Matt fixed the problem below, unbreaking 'master', but this should never
have been merged when (a) the nightlies failed, (b) the branch cannot be
compiled on any machine, and (c) the result of the merge cannot be
compiled on any machine.
Remember that when integrating (e.g., to 'next', 'master', etc), you
should _always_ build the result of the merge before pushing.
commit 275476c694b7affb79a129990509c16cc25cadec
Author: Matthew G. Knepley <knepley at gmail.com>
Date:   Wed Jul 3 17:23:45 2013 -0500
    Mat: Need a scope when declaring variables in a switch block
diff --git a/src/mat/impls/aij/mpi/mpimatmatmult.c b/src/mat/impls/aij/mpi/mpimatmatmult.c
index bf6f620..f924000 100644
--- a/src/mat/impls/aij/mpi/mpimatmatmult.c
+++ b/src/mat/impls/aij/mpi/mpimatmatmult.c
@@ -823,6 +823,7 @@ PetscErrorCode MatTransposeMatMult_MPIAIJ_MPIAIJ(Mat P,Mat A,MatReuse scall,Pets
       ierr = MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ_nonscalable(P,A,fill,C);CHKERRQ(ierr);
       break;
     case 2:
       Mat         Pt;
       Mat_PtAPMPI *ptap;
       Mat_MPIAIJ  *c;
@@ -833,6 +834,7 @@ PetscErrorCode MatTransposeMatMult_MPIAIJ_MPIAIJ(Mat P,Mat A,MatReuse scall,Pets
       ptap->Pt = Pt;
       (*C)->ops->mattransposemultnumeric = MatTransposeMatMultNumeric_MPIAIJ_MPIAIJ_matmatmult;
       PetscFunctionReturn(0);
       break;
     default:
       ierr = MatTransposeMatMultSymbolic_MPIAIJ_MPIAIJ(P,A,fill,C);CHKERRQ(ierr);
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130703/d3e4df67/attachment.sig>
