[petsc-dev] Use KSPSetUpNorms_Private() in KSPSetFromOptions()
Dmitry Karpeev karpeev at mcs.anl.gov
Wed Feb 27 10:41:23 CST 2013
On Tue, Feb 26, 2013 at 8:59 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> On Feb 26, 2013, at 9:54 PM, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
> > Here's what I get with this simple example (source and makefile also
> attached):
> > #include <petscksp.h>
> > #undef __FUNCT__
> > #define __FUNCT__ "main"
> > int main(int argc,char **args)
> >   KSP            ksp;
> >   PetscErrorCode ierr;
> >   PetscInitialize(&argc,&args,(char*)0,(char*)0);
> >   ierr = KSPCreate(PETSC_COMM_WORLD, &ksp);CHKERRQ(ierr);
> >   ierr = KSPSetPCSide(ksp, PC_RIGHT);CHKERRQ(ierr);
> >   ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
> >   ierr = KSPDestroy(&ksp);CHKERRQ(ierr);
> >   PetscFinalize();
> > Then
> > [hal3 Tue Feb 26 09:34 PM]
> ~/petsc/dev/c/src/ksp/ksp/examples/tutorials/tmp >./ex -ksp_type preonly
> -ksp_pc_side left
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: No support for this operation for this object type!
> > [0]PETSC ERROR: KSP preonly does not support RIGHT!
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: Petsc Development HG revision:
> 55699a42ce9360fb4641931ab7ec242cba302c58  HG Date: Mon Feb 25 22:15:44 2013
> -0500
> > [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> > [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > [0]PETSC ERROR: See docs/index.html for manual pages.
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: ./ex on a arch-gxx-real named hal3 by karpeev Tue Feb 26
> 21:37:13 2013
> > [0]PETSC ERROR: Libraries linked from
> /home/karpeev/petsc/dev/c/arch-gxx-real/lib
> > [0]PETSC ERROR: Configure run at Tue Feb 26 17:50:35 2013
> > [0]PETSC ERROR: Configure options --PETSC_ARCH=arch-gxx-real
> --download-f-blas-lapack=1 --download-mpich=1 --with-cc=gcc
> --with-clanguage=C++ --with-cxx=g++ --with-dynamic-loading=1
> --with-python=1 --with-scalar-type=real --with-shared-libraries=1
> > [0]PETSC ERROR:
> > [0]PETSC ERROR: KSPSetUpNorms_Private() line 385 in
> /home/karpeev/petsc/dev/c/src/ksp/ksp/interface/itcreate.c
> > [0]PETSC ERROR: KSPSetFromOptions() line 409 in
> /home/karpeev/petsc/dev/c/src/ksp/ksp/interface/itcl.c
> > [0]PETSC ERROR: main() line 13 in ex.c
> > application called MPI_Abort(MPI_COMM_WORLD, 56) - process 0
> > [unset]: aborting job:
> > [hal3 Tue Feb 26 09:37 PM]
> > The problem seems to be this clause in KSPSetUpNorms_Private():
> >         if (ksp->normtype == KSP_NORM_DEFAULT && i == KSP_NORM_NONE &&
> ksp->normsupporttable[i][j] <= 1) {
> >           continue; /* Skip because we don't want to default to no norms
> unless set by the KSP (preonly). */
> > It is hit because of the code in KSPCreate_PREONLY() you quoted:
> >   ierr = KSPSetSupportedNorm(ksp,KSP_NORM_NONE,PC_LEFT,2);CHKERRQ(ierr);
> /* LEFT/RIGHT is arbitrary, so "support" both */
> >   ierr = KSPSetSupportedNorm(ksp,KSP_NORM_NONE,PC_RIGHT,1);CHKERRQ(ierr);
> > The problem is that PC_RIGHT is preferred by KSP_NORM only with priority
> 1, which is too weak to overcome
> > that "continue" clause above.
>    Ok, this is a bug, we'll leave it to Jed to fix properly since he
> created this Frankensteinen monster.
Is increasing priority of PC_RIGHT to 2 in KSPPREONLY an option as an
interim solution?
It would be nice to patch petsc-3.3 with it, since codes like Moose are
likely to keep using it for a while.
Dmitry.
> > One way to fix it is to jack up the priority of PC_RIGHT, but I still
> don't understand why this combination
> > of norms and pc sides is being figured out in KSPSetFromOptions()
> (twice) with only partial KSP data.
>    Because it want's to give as reasonable a possible solution to the user
> before the user gets to override with something else.
> > And then again, this time "for real", in KSPSetUp().
> > Dmitry.
> > On Wed, Feb 27, 2013 at 2:52 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> > On Feb 26, 2013, at 4:44 PM, Dmitry Karpeev <karpeev at mcs.anl.gov> wrote:
> > > These calls compute default values for normtype and pcside based on
> partial KSP options,
> > > which can cause an unwarranted error to be thrown.
> > > For example, in code there may be
> > > KSPSetPCSide(ksp, PC_RIGHT); /* hardwired default, e.g., in Moose. */
> > > Now, when I'm using command-line arguments
> > > -ksp_type preonly
> > > an error is thrown, since KSPPREONLY doesn't work with PC_RIGHT.
> >   Huh?
> > EXTERN_C_BEGIN
> > #undef __FUNCT__
> > #define __FUNCT__ "KSPCreate_PREONLY"
> > PetscErrorCode  KSPCreate_PREONLY(KSP ksp)
> >   PetscFunctionBegin;
> > Is it because MOOSE also hardwires the norm type and preonly doesn't
> support it? What is the full and complete error message.
> > > Fine, I try
> > > -ksp_type preonly -ksp_pc_side left
> > > but still get the same error, since KSPSetUpNorms_Private() is called
> after KSP type has been set to KSPPREONLY,
> > > but BEFORE there was a chance to set the PC side!
> > > Is there any reason to keep these calls to KSPSetUpNorms_Private() in
> KSPSetFromOptions()?
> >    I think they are there so that users can overwrite them in the rest
> of KSPSetFromOptions(). If you move them to KSPSetUp() then the user cannot
> reset them.
> >    Barry
> > > KSPSetUpNorms_Private() will be just about the first thing called in
> KSPSetUp() and will compute the appropriate normtype and pcside,
> > > but now based on complete KSP options.
> > > Not to mention that calling XXXSetUp_YYY() XXXSetFromOptions() seems
> generally contrary to PETSc's design
> > > philosophy.
> > > Dmitry.
> > <ex.c><makefile>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130227/84d4f6a7/attachment.html>
