[petsc-dev] make -j not supported? Why???
Nystrom, William D wdn at lanl.gov
Mon Feb 25 17:06:56 CST 2013
How do I make sure I am using the cmake based build and not the legacy build?  My build process
looks like the following:
  NJ=16
  configure \
      --PETSC_DIR=$PETSC_DIR \
      --PETSC_ARCH=$PETSC_ARCH \
      --download-cmake=yes \
      --download-f-blas-lapack=yes \
      --with-mpi=1 \
      --with-mpi-dir=$MPI_ROOT \
      --with-openmp=1 \
      --with-pthreadclasses=1 \
      --with-threadcomm=1 \
      --with-shared-libraries \
      --with-debugging=0 \
      --with-make-np=$NJ \
      --FOPTFLAGS="-O3" \
      --COPTFLAGS="-O3" \
      --CXXOPTFLAGS="-O3" \
      --with-c2html=0 \
      --with-large-file-io=1
  make all
From: petsc-dev-bounces at mcs.anl.gov [petsc-dev-bounces at mcs.anl.gov] on behalf of Barry Smith [bsmith at mcs.anl.gov]
Sent: Monday, February 25, 2013 3:49 PM
To: For users of the development version of PETSc
Subject: Re: [petsc-dev] make -j not supported?  Why???
On Feb 25, 2013, at 2:30 PM, Tim Tautges <tautges at mcs.anl.gov> wrote:
>  but why its need to not support otherwise-standard make options?  Similarly, PETSC_MAKE_STOP_ON_ERROR instead of make -k?
   Hmm, with the cmake based build -k seems to work fine, it keeps on going compiling everything it can. Without the -k it stops when the first compile fails. So it is supporting the "otherwise-standard make options".
   Yes, the legacy build which is only a fallback for when cmake fails, is funky. Are you using it? If so, let us know why and we'll try to improve the cmake version so that you don't need the legacy; even I don't use it any more.
   Barry
> - tim
> "You will keep in perfect peace him whose mind is
>  steadfast, because he trusts in you."               Isaiah 26:3
>             Tim Tautges            Argonne National Laboratory
>         (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
> phone (gvoice): (608) 354-1459      1500 Engineering Dr.
>            fax: (608) 263-4499      Madison, WI 53706
