[petsc-dev] make -j not supported? Why???
Tim Tautges tautges at mcs.anl.gov
Mon Feb 25 14:30:17 CST 2013
tautges at chronos:~/code/petsc-dev-moab$ make -j 8
********************* ERROR *************************
Parallel build with 'make -j' is not supported
make: *** [chk_makej] Error 1
Why??? I can almost understand petsc's justification for its own autotools-looking python-based build system, but why
its need to not support otherwise-standard make options?  Similarly, PETSC_MAKE_STOP_ON_ERROR instead of make -k?
- tim
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
  phone (gvoice): (608) 354-1459      1500 Engineering Dr.
             fax: (608) 263-4499      Madison, WI 53706
