[petsc-dev] Alternatives to cholmod
Thu Feb 21 17:38:30 CST 2013
On Thu, Feb 21, 2013 at 4:47 PM, Dave Nystrom <dnystrom1 at comcast.net> wrote:
> I've been using cholmod from SuiteSparse for over a year now to solve one
> of
> my linear systems that is difficult to solve with an iterative method.  Are
> there other sparse direct solvers, such as clique, that I should try
> sometime?  My linear system is SPD and I am solving it on a single node.
>  My
> code has not yet been parallelized using MPI - it is only a 2D code.
Clique is a distributed memory package, though of course it can be used in
serial. You can also try MUMPS. But Cholmod should be a good package for
this scenario. Are you having problems with it or just looking for other
(likely slower) packages to spend time installing?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130221/24039b76/attachment.html>
