[petsc-dev] Need mechanism to set LocalToGlobal mapping in a DMShell
Thu Feb 21 13:10:54 CST 2013
On Thu, Feb 21, 2013 at 2:07 PM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
> On Thu, Feb 21, 2013 at 1:05 PM, Peter Brune <prbrune at gmail.com> wrote:
>> The Set is the issue at hand;
> I think he needs scatters, not ISLocalToGlobalMappings, as mentioned in my
> other email.
Yes, he needs the local to global scatters. Rich, I think the easiest way
to do this now may be
to define your data layout as a PetscSection (these are all local) using
DMSetDefaultSection(),
and record who owns which point using a PetscSF with DMSetPointSF().
Using this information, the DM will automatically construct a scatter
between local and global,
and the CreateLocal/GlobalVector() functions will also work right. This is
what its is designed for.
Does this make sense?
   Matt
>> and it probably belongs in DMShell as a Set/SetCreate pair like
>> everything else in DMShell.
> Yes
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130221/8f747c21/attachment.html>
