[petsc-dev] Error with ML preconditioner
Mon Feb 18 17:02:14 CST 2013
On Mon, Feb 18, 2013 at 4:04 PM, Mark F. Adams <mark.adams at columbia.edu>wrote:
> Yes it should be removed, I just deleted the whole section and tested it.
> We could reinstate this code and check that all processors have a blocked
> index set before making blocked ISs.
I don't want to add another MPI_Allreduce to the critical path (executed on
each assembly). So we either make it strict enough to error if you declare
a block size and don't fill in the blocks, we always fill in the blocks for
you (maybe costing memory), we make the VecScatter permissive enough to
have padded blocks, or we never optimize for the blocks.
To answer this, we have to decide how much the block size attribute is
about the _interface_ (MatSetValuesBlocked) and how much is about data
structure optimizations.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130218/3d2786b1/attachment.html>
