[petsc-dev] Forward declarations of types?
Fri Feb 15 15:41:14 CST 2013
  Since google declared calorically that one cannot do this in C and I refuse to have
#if !defined(PETSCDRAWLGTYPEDEFED)
typedef struct xxx
#define PETSCDRAWLGTYPEDEFED)
#endif
scattered around I put the typedef of PetscDrawLG into petscys.h then small changes were made to the following files
M include/petsc-private/drawimpl.h
M include/petscdraw.h
M include/petscsys.h
M src/dm/impls/composite/pack.c
M src/dm/impls/da/da1.c
M src/dm/impls/da/da2.c
M src/dm/impls/da/da3.c
M src/dm/impls/da/gr1.c
M src/dm/impls/da/gr2.c
M src/ksp/ksp/interface/eige.c
M src/ksp/ksp/interface/itcreate.c
M src/ksp/ksp/interface/itfunc.c
M src/ksp/ksp/interface/xmon.c
M src/ksp/pc/impls/bjacobi/bjacobi.c
M src/ksp/pc/impls/fieldsplit/fieldsplit.c
M src/ksp/pc/impls/mg/mg.c
M src/ksp/pc/interface/precon.c
M src/mat/impls/aij/mpi/mpiaij.c
M src/mat/impls/aij/seq/aij.c
M src/mat/impls/baij/mpi/mpibaij.c
M src/mat/impls/baij/seq/baij.c
M src/mat/impls/dense/mpi/mpidense.c
M src/mat/impls/dense/seq/dense.c
M src/mat/impls/sbaij/mpi/mpisbaij.c
M src/mat/impls/sbaij/seq/sbaij.c
M src/mat/matfd/fdmatrix.c
M src/snes/impls/fas/fas.c
M src/snes/interface/snes.c
M src/sys/classes/draw/impls/x/ftn-custom/zdrawopenxf.c
M src/sys/classes/draw/interface/ftn-custom/zdrawf.c
M src/sys/classes/draw/interface/ftn-custom/zdrawregf.c
M src/sys/classes/draw/interface/ftn-custom/zdtextf.c
M src/sys/classes/draw/interface/ftn-custom/zdtextvf.c
M src/sys/classes/draw/interface/ftn-custom/zdtrif.c
M src/sys/classes/draw/utils/axis.c
M src/sys/classes/draw/utils/axisc.c
M src/sys/classes/draw/utils/axisimpl.h
M src/sys/classes/draw/utils/dscatter.c
M src/sys/classes/draw/utils/ftn-custom/zaxisf.c
M src/sys/classes/draw/utils/ftn-custom/zzoomf.c
M src/sys/classes/draw/utils/hists.c
M src/sys/classes/draw/utils/lg.c
M src/sys/classes/draw/utils/lgc.c
M src/sys/classes/draw/utils/lgimpl.h
M src/sys/classes/viewer/impls/draw/vdraw.h
M src/ts/interface/ts.c
M src/ts/interface/tseig.c
M src/vec/vec/impls/mpi/pdvec.c
M src/vec/vec/impls/seq/bvec2.c
M src/vec/vec/utils/cmesh.c
I'm fine with doing this. Is there a better solution?
   Barry
On Feb 15, 2013, at 12:38 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   How does one prevent this problem?
> [ 15%] Building C object CMakeFiles/petsc.dir/src/ksp/pc/impls/is/nn/nn.c.o
> In file included from /Users/barrysmith/Src/petsc-dev/src/ksp/pc/impls/bjacobi/bjacobi.c:184:
> /Users/barrysmith/Src/petsc-dev/include/petscdraw.h:283: error: redefinition of typedef ‘PetscDrawLG’
> /Users/barrysmith/Src/petsc-dev/include/petscksp.h:598: error: previous declaration of ‘PetscDrawLG’ was here
> On Feb 15, 2013, at 11:28 AM, Jed Brown <jedbrown at mcs.anl.gov> wrote:
>> We currently use recursive includes everywhere, so petscdmda.h includes all of petscao.h just so it can declare DMDAGetAO and similar. Of course most users of (and implementation files in) DMDA do not reference AO so they don't need to know about all the AO functions.
>> The normal approach to this is to forward-declare the type, so instead of
>> #include <petscao.h> /* includes lots of other stuff */
>> PETSC_EXTERN PetscErrorCode DMDAGetAO(DM,AO*);
>> one would write
>> typedef struct _p_AO *AO;
>> in which case all three files in PETSc that actually call AO routines would need to include petscao.h. That is arguably a good thing since it makes the actual dependencies more explicit, and is recommended by many (mostly C++) style guidelines.
>> Is this something worth considering? I think stuff like petscvec.h and petscmat.h ends up pretty much always being needed, but petscdm.h is only used by a handful of files in petscksp and above, for example.
>> It might be nice to get rarely-used stuff like petscdraw.h out of petscsys.h.
