[petsc-dev] I hate this one
Karl Rupp rupp at mcs.anl.gov
Wed Feb 13 10:54:59 CST 2013
>> the checks are in src/contrib/style/checks/. You can run them from PETSC_DIR, but they currently check the full source tree only.
>     Karl will be modifying them to be able to run directly on single source files and subdirectories.
And on modified files obtained from `hg status`... Same should work for
uncrustify.
Best regards,
Karli
