[petsc-dev] Fix for mataijcusp.cu
Jose E. Roman jroman at dsic.upv.es
Wed Feb 13 08:36:15 CST 2013
El 13/02/2013, a las 15:17, Barry Smith escribió:
>   Thanks for noting this. Is the problem the (*right)->map operation in?
> ierr = PetscLayoutReference(mat->cmap,&(*right)->map);CHKERRQ(ierr);
>   This can be corrected easily by replacing the PetscLayoutReference() here with VecSetLayout(). Does that resolve the problem?
>   General note:   We should really move the PetscLayout operations out of Vec mpi impl location.
>   Barry
Yes it works.
https://bitbucket.org/petsc/petsc-dev/commits/8264b0c102238be7a957e713db98c3d5
By the way, I am getting a warning which I think is new - when compiling with nvcc in optimized builds:
/home/jroman/soft/petsc-dev/include/petsc-private/petscimpl.h(201): warning: "cc" clobber ignored
Jose
