[petsc-dev] removing PETSC_NULL from petsc-dev
Wed Feb 13 06:43:47 CST 2013
On Thu, Feb 7, 2013 at 9:56 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
> I have removed the use of PETSC_NULL from all PETSc C code. Please
> remember to just use NULL in PETSc source code in the future (or Karl's
> script will find you).
I see you changed to
#define PETSC_IGNORE NULL
but kept
#define PETSC_NULL 0
Should the second be updated to
#define PETSC_NULL NULL
because it is stricter about passing PETSC_NULL for an integer argument?
Also, we could do something like this (properly guarded, of course):
__attribute__((deprecated)) PETSC_UNUSED
PETSC_STATIC_INLINE void PETSC_NULL_IS_DEPRECATED_JUST_USE_NULL() {};
#define PETSC_NULL           (PETSC_NULL_IS_DEPRECATED_JUST_USE_NULL(),NULL)
which can be used for any compiler that supports non-static statements in
declarations (everything but Sun and MSVC?) and has
__attribute__((deprecated)). This produces warnings like this under Clang
ex5.c:102:36: warning: 'PETSC_NULL_IS_DEPRECATED_JUST_USE_NULL' is
deprecated [-Wdeprecated-declarations]
  ierr       =
PetscOptionsGetReal(PETSC_NULL,"-par",&user.param,NULL);CHKERRQ(ierr);
/home/jed/petsc/include/petscsys.h:387:31: note: expanded from macro
'PETSC_NULL'
/home/jed/petsc/include/petscsys.h:385:33: note:
'PETSC_NULL_IS_DEPRECATED_JUST_USE_NULL' declared here
PETSC_UNUSED static inline void PETSC_NULL_IS_DEPRECATED_JUST_USE_NULL() {};
1 warning generated.
and like this with GCC:
ex5.c: In function ‘main’:
ex5.c:102:3: warning: ‘PETSC_NULL_IS_DEPRECATED_JUST_USE_NULL’ is
deprecated (declared at /home/jed/petsc/include/petscsys.h:385)
We can make the error message cleaner (but more confusing) with
PETSC_UNUSED static inline void PETSC_NULL() {};
#define PETSC_NULL           (PETSC_NULL(),NULL)
which produces:
ex5.c:102:3: warning: ‘PETSC_NULL’ is deprecated (declared at
/home/jed/petsc/include/petscsys.h:385) [-Wdeprecated-declarations]
Any sense in this stuff?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130213/37e376d9/attachment.html>
