[petsc-dev] Stricter header includes
Tue Feb 12 16:41:58 CST 2013
On Tue, Feb 12, 2013 at 4:37 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Tue, Feb 12, 2013 at 5:34 PM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>>    Certain PETSc "functions" are documented as being "Developer" level.
>> Does this mean they will be in a "developer" API as opposed to the "user"
>> API (for example in xxximpl.h instead of petscxxx.h)?  Or will there not be
>> a "developer" API at all and xxximpl.h merely provides access to the direct
>> data structure.
> I thought Developer meant "we are still figuring this out", or "you can
> really hurt yourself here", not "this is secret".
That was my impression too. I thought the actual internal stuff did not
have a generated man page.
It's possible to be a bit more strict about this by enabling visibility.
When configured using --with-visibility, internal functions become
"invisible" outside the shared library (even those that aren't file-local).
To make that more precise and explicit, we could use PETSC_INTERNAL instead
of PETSC_EXTERN for those functions.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130212/ef3ed086/attachment.html>
