[petsc-dev] Fwd: petsc/petsc-dev added -valgrind -debugger option to petscmpiexec (commit 398f06830ac9d0920f8d4e4d0bac972857d520d4)
Tue Feb 12 11:51:14 CST 2013
Okay, pushed
https://bitbucket.org/petsc/petsc-dev/commits/1b382c0c8a0048fa000c4641e30980e1ca800f19
On Tue, Feb 12, 2013 at 11:37 AM, Barry Smith <bsmith at mcs.anl.gov> wrote:
>   Stupid bitbucket doesn't let me respond to this.
>     I think this is to handle the case where the vectors were obtained
> without the appropriate block size so the routines called below cannot be
> work properly. Perhaps the code should be changed so that the x and y bs
> are only set if the jac->bs is a legitimate value and not when it is -1.
>    Barry
> Begin forwarded message:
> > From: Jed Brown <Bitbucket <commits-noreply at bitbucket.org>>
> > Subject: Re: petsc/petsc-dev added -valgrind -debugger option to
> > Date: February 12, 2013 7:10:23 AM CST
> > To: bsmith at mcs.anl.gov
> > New comment on changeset:
> https://bitbucket.org/petsc/petsc-dev/commits/398f06830ac9d0920f8d4e4d0bac972857d520d4#comment-146984
> > Jed Brown (jedbrown) said:
> > What is this trying to achieve? In `runex19_4`, this results in changing
> the block size from `4` to `-1`. Can we delete these lines or do we need to
> set `jac->bs` in that case?
> > This is an comment notification from bitbucket.org.
> > You are receiving this because you are participating
> > in a comment thread.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-dev/attachments/20130212/4c8db49c/attachment.html>
